NXT vs NXT 2.0
Old 06-24-2008, 12:43 AM
ThumperMX113's Avatar
I use #34 for after washes and quick touch-ups. It's kind of expensive to use for a clay lube, IMO, but a lot of people do it. Personally, I just use the A-Line QD for clay lube since it's so cheap and widely available.
  #32
Old 06-24-2008, 09:39 AM
pmason718's Avatar
ok ok ok. I love Rick and I appreciate his outstanding customer service but this time around I had to order from autogeek in order to receive my items by Friday.
This is what I ordered
#34 Gallon
#34 16oz bottle
#26 16oz bottle
Megs mild clay bar
Poorboys wheel sealant
Supreme 530 MF towel (I figured that I would give these a try)
Im slowy rebuilding my collection. The reason I say rebuilding is b/c Im in the process of going from Megs consumer line to their pro and detailer line. I will eventually start trying other products but as of right now Im very comfortable with Megs. I've always been a big clean car/truck kind of guy before I joined the forum but now with advice and more resources at hand I can only get better.
Once again here is my approach for this weekend. Correct me if I'm wrong
Proper wash and dry.
Clay Bar (Megs Mild)
Megs Deep paint cleaner
NXT 2.0 (let it cure for 12hrs)
  #33
Old 06-24-2008, 10:18 AM
hwm3's Avatar
Originally Posted by sal150
Sorry to threadjack
I know that #34 is a good Qd but ive heard that some people use it primarily for clay lube...and quick touchups is this true. Cause i cant keep buying the quik detailer 16oz's. If not what do you use.
I use ONR diluted as my clay lube. Works very well and is much cheaper than using a QD.
  #34
Old 06-24-2008, 11:21 AM
Procedure looks fine. What does the paint look like? Do you need something that's a paint corrective polish?
  #35
Old 06-24-2008, 12:44 PM
Iam4st8's Avatar
So, basically soapy water? [ONR is a car wash soap right?]
  #36
Old 06-24-2008, 01:29 PM
glc is offline
Use the cheapest QD you can find for a clay lube. Soapy water will work fine BUT it will deteriorate the clay.
  #37
Old 06-24-2008, 03:06 PM
hwm3's Avatar
Not every car wash soap can be used like this. ONR is diferent.
http://autogeek.net/optimum-no-rinse.html
  #38
Old 06-24-2008, 03:07 PM
hwm3's Avatar
Standard car wash soap will, but ONR won't.
  #39
Old 06-24-2008, 03:09 PM
gators241987's Avatar
Ohh, good ole ONR. Quick tip, buy it, buy gallons of it. you will wonder what you did before you bought it after you try it out a few times.
  #40
Old 06-24-2008, 03:34 PM
I hope I like Poorboy's Spray & Wipe as much as ONR.
  #41
Old 06-25-2008, 02:59 PM
sal150's Avatar
Thanks everyone i figured that ONR was used for other stuff. I'm paying 5 dollars for those megs quix detailers and i use all of it on one car. Guess im gonna have to Grab a gallon or so of ONR. thanks again
  #42
Old 06-25-2008, 03:03 PM
sal150's Avatar
Forgot to write this in
Tell me how you like it when you use it. i was gonna pick some up a while ago but im not so big on QD's either i hate swirls on a black truck
  #43
Old 06-25-2008, 03:50 PM
No problem, I'm still waiting on the order though.
Quick Reply: NXT vs NXT 2.0
