General all purpose cleaner?
Old 06-24-2008, 07:13 PM
FX4Screwdude's Avatar
Is there something thats safe I can use for a all around cleaner..
Floor mats, interior plastic, interior trim, steering wheel. etc...
The door handles, arm rests are getting kinda gunky looking and I need to clean it.
Old 06-24-2008, 08:36 PM
Ranger7489's Avatar
armorall, just dont put it on your steering wheel, pedals, or shifter (its its manual)
Old 06-24-2008, 08:39 PM
ThumperMX113's Avatar
I'd use Meguiars APC+ just use proper dilution ratios for it.
Yuck. Armorall isn't a cleaner. It's a dressing.
Old 06-24-2008, 08:48 PM
ian51279's Avatar
I dilute some Simple Green for interior duties. I've used 409 and others in a pinch.
Old 06-24-2008, 09:27 PM
gilsnuxs's Avatar
X2
Old 06-25-2008, 07:55 AM
Is that available at local auto stores (which ones) or only online?
And what about this one
http://www.autogeek.net/dp340.html
Old 06-25-2008, 07:56 AM
AsheFX4's Avatar
I love the Tropi-Care TC-10 Leather/Vinyl/Fabric cleaner.
Old 06-25-2008, 12:23 PM
The DP Interior Cleaner is some good stuff. DP makes a lot of good products.
I'd still pick up some Meguiars APC+ because it's simply awesome. It's by far one of my favorite products.
Old 06-25-2008, 12:33 PM
tcope's Avatar
I'd not use harsh non-specific chemicals on the interior. If it's leather, leather cleaner. If it's plastic, plastic cleaner, etc. With that said, most of what you mentioned is going to be plastic. I tend to use Vinylx by Lexol or Aerospace Protectant by 303 but these are technically not "cleaners". They treat the plastic and protect it. But once used and with semi-regular cleanup, they work just fine.
If there is a lot of dirt embedded I'd try using a mild soap and water with a soft brush and toothbrush for small areas. But I really think the items mentioned above would do the trick. But the bottom line is that I'd use cleaners specific to the material being cleaned (plastic).
Old 06-25-2008, 01:01 PM
Rockpick's Avatar
Moderator &
Great advice tcope. APC+ can be pretty darn harsh when used incorrectly...
As is the recommendation with a polish for paint, you'll want to go with the least aggressive method to accomplish your task in the safest fashion. Even APC+ at 10:1 can be pretty aggressive...
I've not yet tried it but Boss_429 - who *is* probably the most experienced detailer with the most extensive chemical-usage knowledge on this site - recommends 303 Aerospace Cleaner for many APC-types of jobs. I have not yet tried it but, if Boss says it's the best stuff that he's used, we all should listen.
-RP-
Old 06-25-2008, 01:16 PM
Agreed. I wouldn't ever use APC+ at 10:1 on anything in the interior. I don't even think it's diluted enough for the carpets. I usually do something close to 20:1 and it seems to work great. I was leary at first about using it because the stuff will burn your hands. I tested on some unseen areas of different materials and at a dilution ratio of 20:1 or so it didn't have any discoloring, staining, etc.
Old 06-25-2008, 09:14 PM
Rockpick's Avatar
Moderator &
10:1 is actually primo for carpet cleaning. I keep a bottle mixed at 10:1 for my home carpets... 10:1 is the recommended dilution, per Meguiar's, for interior 'stuff'.
Old 06-26-2008, 01:13 AM
andrewc_11890's Avatar
Aren't you also not supposed to use Simple Green on Carpet at all because it tends to break down the threads in the carpet very slowly?
I think I read that in the sticky, can someone confirm that?
Old 06-26-2008, 09:49 AM
pmason718's Avatar
Im no expert (not yet, lol) but I can tell you what I like. For my interior plastics I love to use Meguiars Quik Interior Detailer
Quiik Detailer
http://www.meguiars.com/?vinyl-rubbe...erior-Detailer
and for my carpet I've given Meguiars Quik out a shot and I like it. At the same time my interior is not shot so with that said I think that the products you choose all boils down to what condition your interior is in.
Quik Out
http://www.meguiars.com/estore/product_list.cfm?sectionname=Consumer%20(Meguiar's %20Brand)>Car%20Interior%20Care>Cloth/Carpet%20Cleaners&sectionID=12301
Im pretty sure if you post pics of your interior that one of the experts on here can steer you in a better direction. Also the two products that I mention can be purchased locally at Autozone, etc. if you need them right away.
Old 06-26-2008, 10:16 AM
I know that's what Meguiars recommend, it's right on the bottle. However, I've used it with poor results because it was too strong, of course this was on a very old car but still ... More than one way to skin a cat, right?
Quick Reply: General all purpose cleaner?
