can you guys look over my order??
ok guys, im looking at makeing a purchase through ADS or Autogeek.
first things first, The truck is a 2008 BLACK! F150. no major scratches or major blemishes. very small abrasion marks from regular washing. here is what im thinking about getting.
- SSR2
- SSR1
- Black Hole
- EX-P
- Natty's Blue
- Flex XC3401 VRG Dual Action 6.5 inch Pad kit.
- 1 Foamed Wool 6.5 inch polishing/buffing pad
- 1 CCS Orange 6.5 inch light cutting Foam pad
- 2 CCS White 6.5 inch Polishing Foam Pads
- 1 CCS Grey 6.5 Inch Finishing Foam Pad.
- 1 CCS Blue 6.5 Inch Finessing Foam Pad
- 2 Cobra Indigo Edgless Microfiber Polishing Cloths
- 4 Cobra Microfiber 6.5 inch bonnets
- 12 oz. Pinnacle XMT Polishing Foam Pad Cleaner
- 12 oz. Pinnacle XMT Polishing Foam Pad Conditioner
So what do you guys think?? will this take care of the truck? Anything that i should dump? Anything that i should pick up? im open to any and all suggestions. i just want to be buying the best for my truck. Thanks in advance.
- SSR2
- SSR1
- Black Hole
- EX-P
- Natty's Blue
The code is a discount code. Just type it in and you'll get a discount. Personally I think everything looks great. Make sure you've got some nice wash mitts. I like the SM Arnold Lambs Wool Mitts. Get two grit guards, Hyperdressing, APC+, and probably some more microfibers. Also, I always recommend this, buy the bottles that are made for each product. They have the proper dilution ratios on them and it makes your life a whole lot easier. I'd even get two for the Hyperdressing so you can have two different dilution ratios mixed up at all times. I currently run 1:1 for my tires and 3:1 for everything else, I'll be switching that to 4:1 soon enough. NXT and #21 are the same thing. I'd advise you to get #21 if you're going to be ordering it but EX-P is a great sealant. Natty's Blue is a great carnuba for dark colors but it doesn't have a lot of durability. It's okay though since you'll be running the EX-P. I hope this helps.
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
