Buff it baby!
That's correct, from what I understand about the product. PB PP is actually more of a chemical polish than an abrasive polish. As such, it may have a little more of a 'filling' ability versus that of a removal ability.
Also, despite the fact that it says 'non-abrasive', I've read that Steve ("THE" Poorboy) stated that it has some VERY minor (emphasis added) abrasives.
So, in a nutshell, relating it back to a chemical or two that I certainly understand and use -- I'd compare it to a #9 or a MPPC (Meg's Medallion Premium Paint Cleaner).
-RP-
So, in a nutshell, relating it back to a chemical or two that I certainly understand and use or have used -- I'd compare it to a #9 or a MPPC (Meg's Medallion Premium Paint Cleaner (discon'd)).
-RP-
I would bet that it will get them out by hand with an aggressive terry cloth followed up by a final buff to remove the marring caused by the aggressive towel.
PP is a pure chemical polish. It is as abrasive as you make it (does not contain abrasives). It can remove 2,000 grit wet sand marks and also be used as a final polish. PP also has no fillers in it and will not hide a thing what you see is what you get.
I use PP, and use it often. The difference is I don't use it to remove defects, I use it as a final gloss enhancer after all defect removal is complete.
Here are some pictures of what I ended up with. These were actually taken a day after it had been cleaned because I forgot to grab the camera.
This is what I did...
Wash Gold Class
Clayed with Meguiar's kit
DC Step 1
DC Step 2
NXT 2.0
I still want to buff it out good but just haven't got around to buying a good buffer yet. The DC did a decent job of getting out alot of the really noticeable stuff but you can still see a little when the light hits it just right. I wanted to top of with #26 but my friends called me up to go out boating and I can't say no to that!
This pics aren't the best because it was starting to get dark out.
Wash Gold Class
DC Step 1
DC Step 2
NXT 2.0
