Buff it baby!
Buff it baby!
This is a picture of my wifes 06 Zephyr hood that I took last night. It's kind of hard because of the lighting but you can see the swirling in the paint. What steps should I take to correct this paint? I currently do not have a buffer so I'm probably already one step behind. Any advise would be appreciated!
Nearly certain that this procedure won't remove them though...
The DC system *may* deal with most of it however; I think you'll likely need to use something with a bit more cut to really take care of that problem by hand... also, I think it should be stated here that 'by hand' will equal 'arm cramps from hell'. You've got your work cut out for you if you go with the 'by hand' methodology...
That was my first thought. Might can remove a little bit by hand with ScratchX and as far as OTC stuff by hand I'd suggest Clay, ScratchX (in spots), Step 1, Step 2, & Step 3 (of Meg's 3 step).
Just be forewarned that you're not going to be "removing" much of anything by hand. You're going to be hiding "a lot". So it'll look great! But, when it wears off they'll be back and it'll have to be done all over again.
NXT 2.0 can hide it to some degree. It does have some polishes and fillers, but you need something stronger first like ColorX, DC step 1, or something from the D-line.
By hand, I prefer to replace step 2 and step 3 with NXT 2.0. It's one less step. Some of you may disagree, but for a casual hand detailer it does a decent job.
Your BEST bet would be to buy a polisher and the appropriate pads and products to do it right. A DA is safest in the hands of a novice.
3 step = Meguiars Deep Crystal.
Step 1 - cleaner
Step 2 - polish
Step 3 - wax
To review, this is what I recommend for casual use by hand.
Wash
Clay
DC step 1 or ColorX
ScratchX in needed spots, redo the Step 1 or ColorX after
NXT 2.0
Step 1 - cleaner
Step 2 - polish
Step 3 - wax
Wash
Clay
DC step 1 or ColorX
NXT 2.0
I think glc meant the M-Line rather than the D-Line... although, the D-Line has a product or two that could help the situation. Just a bit of clarification....
By hand... I concur with glc's prescription. The key is to NOT move on to the next step until you're satisfied with the step you just completed. DO NOT be afraid to go multiple 'times' with a product.
Also, it's important to point out here that Color-X is a cleaner wax (a very good one, too). As such, it may make a bit more sense (if it's working, that is) to go with the DC #1 with multiple passes until you're 'just about there'. On that last time, use the Color-X. This will leave behind a layer of protection and then you'll be ready to pop the NXT... while NXT on top of Color-X isn't necessarily the perfect plan, it'll certainly work and will offer very good, long term, protection.
Let us know if you have any other questions!
GOOD LUCK!
-RP-
GOOD LUCK!
-RP-
PB Pro Polish with a cotton terry towel then finish it up with a "diaper" like towel for the final buff. Remember to always remove the product with MF towels. You will then have to go over the paint with some sort of protection either wax or sealant.
This should come out with the above process i have done much worse by hand and yes the "arm cramp from hell ()" is right on :o
Good luck
Good luck
Good luck
Good luck
