what to do before winter ?
So just as the economy goes for shi< I decide to buy a new truck. This brings me to a couple of questions.
On my current truck I used SSR1, PB PP, EXP and Natty's (Both trucks are white). The weather is turning to crap here so time is very limited. Should I try to do the same steps before winter or can I apply the Natty's and do the rest come spring ?
Megs Quick detailer. Can I or should I be using this while I dry my truck after a wash?
Thanks for the help.
Yeah quick detailer is good to use after a wash, for water spots etc. Some guys even top a freshly applied coat of wax with it to make the paint deeper.
I'm in Hamilton.
I say synthetic only because it usually lasts longer... I would be more concerned about protection over the winter than it looking perfect.
I'm in Hamilton.
I'm in Hamilton.
If Steve wanted to call EX-P a Syn Wax it would have been on the label but b/c its NOT a wax, he called it a Sealer. Interesting.
But hey, Tomato, Tamoto. Sealers are not waxes (More accurate to understand)
As for what to put on, for the winter I value protection over appearance. My personal favorites for durability are Zaino or Collonite 845 or 476S and they shine quite nicely too. Whatever you choose though, make sure you apply it to all surfaces. That includes door jambs, edges of your tailgate, under the hood, etc. I even run some WD-40 down into the bottom seam on my doors and tailgate. I’ve seen some people up here that believe in applying a wax, but not wiping it off for the winter. The belief here is that one gets more protection. Personally, I think all it gives you is one heck of a mess to try to remove in the spring.
Getting beyond paint and appearance, I also use WD-40 on all lock cylinders, lubricate all hinges and latches with White Lithium grease. I also apply 303 Aerospace Protectant to all rubber door seals. Don’t forget to apply WD-40 to your trailer plug if you have one too. (I even follow that up with purple battery terminal spray.)
If you’re really into getting ready for winter, you also might want to pull your wheels off and apply Never Sieze to the threads on the lugs. If you have aluminum wheels, some of us even apply some to the mating hub surface to prevent the wheel and hub from oxidizing together. And, for the truly ****, you can apply Dielectric Grease to all electrical connections such as light bulbs and weather tight connectors. Hope that helps!
I am at school right now, and dont have too much at my disposal. What I did was I cleaned the truck, and then I used some meguiars cleaner wax, and then put a top coat of Collinite 845 on all of the paint. For my chrome wheels, I used some Turtle Chrome Polish and then followed up with some Collinite 845 on them as well. Collinite is supposed to be one of, if not, the longest lasting wax. We will see I guess...
