Mother's Back to Black
Anyone ever had bad experiences with Back to Black? I used it for the first time over the weekend. It worked great on all exterior plastic but made my rubber window moldings streaky. I think I should've applied it heavier to avoid the streaking. Anyways, wondering what you guys think about this product vs. Meg's HD. I'd like to think either product is actually protecting vs. accelerating the deterioration process.
Thanks for the replies. I will probably switch to HD or try the Bondo afterall. I picked up the Mother's just becuase it was on the shelf and easy to obtain. I've found every detailing product I use on the shelf except for the HD. I guess I need to go to ADS and order some. Much appreciated guys.
What do you use on the black plastic panels between the side windows? Can't tell if they are plastic or metal. Was wondering if most people apply something to protect them.
I have never used anything. They are plastic and mine have held up well. I apply the Bondo Restore Black on the rails about every 3 months. Holds up great. I painted the cowls with Fusion Satin Black and they are holding up well. Someday, maybe I'll get around to using the Fusion on the bed rails. Just lazy, I guess.
Does Hyperdressing restore black color to plastic? Does it run like BtB? Never used HD before. I have some on order as we speak. I'm hoping to use if for trim, moldings, tires, wheel wells....the whole nine yards. One product; many uses. Hope it works out that way anyways. Maybe I'll try the Black Wow if it doesn't work well on plastic.
