Coke exploded
Went I bought my beater Cavi™, it was very obvious that he had an addiction to Mountain Dew, Dr. Pepper, and sunflower seeds. You could also tell that he had spilled a big ole thing of Dr. Pepper on the front right carpet. Sprayed some carpet cleaner on it, let it soak, scrub it in, then wipe up with a towel and all is good. For the windows, I'd use warm hot soapy water. Use that on the door panels also.
DON'T USE STEEL WOOL! You're going to scratch your windows and leave permanent damage. That's horrible advice!
Coke is primarily sugar. Park in a garage and close the door to keep the chill out. Then use very hot water soaked towels and dissolve the coke off of your glass and other parts. Don't soak your interior though. Or, invest in a bissell steam clean machine.
Again, it's just dried up sugar syrup. Don't go causing more damage.
For the windows, since it is probably sticky. Just glass cleaner (Do not use windex on car windows, it destroys your UV coating) and steel wool. Use alot of glass cleaner. This will work if you have aftermarket tinted windows. It will just scratch the heck out of your tint job.
