Tire shine
If the stoners tire works as good as their glass cleaner it must be real good cause their glass cleaner kicks ***.
I recently bought a can of Megs Tire spray and thought it was like the other stuff you guys described but when I went to use it, it was like clear spray paint, even the spray head had several settings, it worked ok but its so much like spray paint it concerns me in that I am concerned if it gets on my paint...
Seems a few are not answering your question so I will but first let me tell you this.
Just like the paint surface, if you don't have a properly prepped tire any dressing you apply will not look right.
So given that, make sure you clean the tire before applying dressing. Someone mentioned stacking above, stacking is only acceptable when using the same product withing reason of the last application. Some key words there. Read it again.
Now to your question. Will HD sling? It sure will. Is it a problem? Not at all....just use a clean MF and some QD and it will be gone as quick as it got there.
I happen to be in the camp of over dress, clean up later. In a pinch I will blot dry the HD if the customer is going to be driving off soon....so that also makes you think about what stage you apply HD or any dressing. Another trick I do is after I apply, I pull the truck/car back or forward so that I get a uniform spray on the surface.
What I do and this is just me.....After a wash, I dry...then I will apply HD to the wells, frame and wheels...pull in the garage then QD the surface. (This is b/c vapor droplets will find there way to the paint)
Once the QD is done, if I am doing a full detail...
Clay
Polish/Correct
Seal
LSP
Wheels are already done.
Hope that helps.
RR
Clay
Polish/Correct
Seal
LSP
Hope that helps.
RR
I use nothing except HD on the tires and have never had an issue with sling, even driving the truck within an hour of application. I spray it on, let it soak in for a couple of minutes then use a tire swipe to spread it over the tire.
http://www.eagleone.com/pages/produc...=1031&cat=5005
This is old school but don't knock it 'till you've tried it. It's all I've used for years. Clean your tires really well with Purple or Westley's or similar and just apply plain old floor wax to your dry tires. It seals the tires and makes it much easier to clean off dried mud, etc. It will give you a nice shiny black tire but not the "wet" look. Cheap too, then you can spend the money you wasted on high priced tire shine on something better. You can get an idea from my old work van here.
i usually spray APC+ on mine but I take it off right away. I guess I need to let it sit for a few seconds.
Personally I think the scrubbing of the tire is more important than letting it dwell. It's not enough to simply spray on and rinse off. Like RR though, I do both. Spray it on, let it sit and scrub it real good. You're set.
