Tire shine
#32
#33
I've never heard of any new formulas having that problem. I use armor all everyday at work and never once have i had a problem.
#35
I wonder if this is true. Tire manufactures put "waxes" into the tires that migrate to the surface when the tire flexes (blooming). These waxes help prevent breakdown from ozone. I've never seen a container of tire shine, etc. that claims to replace these waxes or add wax to the tires. I'd think that spraying these shine products on a tire and then wiping them off would actually remove the protective waxes from the tire. Also, I've almost never seen a dressing claim to protect tires from UV (I've seen plastic protectants claim this but not tire dressings).
Whenever I have used a tire protecting product I've always noticed that I've wiped a black material off the tire. This is not just dirt/grime. I wonder if I'm removing the black carbon from the surface of the tire.
There are some protectants like 303 makes that claim they are not oils so they won't remove the wax. I'd tend to think that any water based tire shine would most likely not remove the wax from a tire but are all tire dressings water based?
#36
