HyperDressing
HyperDressing
Okay another stupid question just recieved my gallon of HD today and also got the Spray bottle. On the mixing ratios what actually is 1:1 2:1 etc meaning how much do i put in for the concentrate and how much water do i add? I didnt get the pumper for the gallon. Hope i explained it good enough
sorry i typed it backwards when i first responded. for natural shine (4:1), it will be 4 parts water to one part HD, so fill the water up to the 4:1 line and then just alittle bit of HD up to the beggining of the neck. Therefore, if you end up using a different ratio like 2:1 you will end up using more HD but will get more shine
Well just used the hd for the first time today. Opened the hood and gently sprayed off the motor to detail it and now i have a big time miss in the motor so im sure i got a cop wet or something. But it looks good on the tires and the wheel wells didnt get a chance to do the motor since i have to change the cops now. Ill put pics up next time i wash truck. One question though i went threw almost half a bottle(megs spray bottle) doing my truck is that normal?
Yeah, it's a dressing that you can use on everything. You can mix it to different dilutions to give you the shine that you want. High gloss or a matte finish. It is water based and you mix it to your preference. Once I used it I was done w/all that expensive stuff at the local auto stores.
http://www.autodetailingsolutions.co...e%20Prices.htm
You use to be able to get a discount if you where a member of f150online.
