Stained my carpet!!!
What I do, is mix a Folex solution in the solution tank. However, I also will spray some on heavy spots that really need a little something extra. The tank on one side is for your cleaning solution and the tank on the other side is for the stuff yo suck up. Then I empty it out and cleaning the unit really good. I rinse clean both tanks until clear water is coming out and then I'll fill a buckit with some water and continue to suck clean water through the hose until that's clear and then rinse the tank clean again.
