Best Product for Vinyl
the 303 will add UV protection...it will run like the wind when wet...so you need a few days of dry to get it right.
303 isn't a Megs product. HD is one of the best products on the market, very versiatle but it doesn't have any UV in it...so for something like that I would mix in a little 303 from time to time.
http://www.autogeek.net/303aerprot.html
As for being a rookie, we all had to start somewhere...hang in there. Read the sticky, visit websites, read, learn and most of all practice....what you know today will only get you through this day, you will learn something new every time you do a detail or use a new product...that makes all of us rookies.
Cheers
RR
Cheers
RR
Hyper Dressing is great, but for actual vinyl you may also want to consider Meguiar's M40. It has mild cleaning agents, and a great matte finish with lasting protection. I use it for interiors since it doesn't leave a gross, oily feeling that collects dust. It can also be used in engine bays or other exterior plastics, rubber, and vinyl.
Hyper Dressing rocks, but is shinier and a little more sticky. I use that for wheel wells, engine bays, and tires.
update----HD does indeed have UV protection in it Just talked to Joe at Megs...
Much appreciated. I asked a rep what his suggestion would be between Gold Class vinyl/rubber and HD. He recommended HD and ensured UV protection.
