What's the best way to seal air leak on passenger side window?
What's the best way to seal air leak on passenger side door?
The rubber around the top of the door is good (not dry or cracked) but it has come away from the door frame. I had tried some adhesive to hold it in place, but it didn't. It's very annoying to hear this leak, especially on the highway. Is there a better adhesive to use? Replace the whole piece? Where's the best source? I'll have to wait a while, too cold now in Wisconsin, but first thing in Spring I need to fix this. Thanks
I think I know what you are talking about. That seal is a ring that goes all the way around the door frame and under the kick plate..I don't think that part would be expensive to replace.
