Why microfiber over chamois or water blade?
I know the microfiber cloth is the recommended method for drying your vehicle, but I'm curious why.
I would figure any dirt particles missed while washing it could get caught in it and be continually dragged.
I would think it would retain more particles than a chamois - leather or synthetic (absorber).
I've seen the California Water Blade, and I'd think with such a thin edge, there may be less potential to retain any dirt on that than either of the other two.
Thanks.
Thanks.
Well, first off all, the proper way to dry a vehicle starts with the sheeting method. Disconnect the hose nozzle and let the water run straight from the hose onto the paint starting from the top and working down, allowing it to sheet off. That will remove the bulk of the water. The microfiber towel take care of the rest of what's left on the imediate surface. And you'll want to pat the surface dry and not drag anything across the paint. The water blade will drag anything left on the paint inducing scratches. The chamois doesn't allow anywhere for the trapped remaining dirt to go. A microfiber towel is soft enough to not scratch paint, gives dirt someplace to go so it's not continuously touching the paint and they hold a lot of water.
I don't recommend using chamois at all, Like ESF said, they just move dirt and contaminants across the paint. You use a large microfiber towel or use a few smaller ones. I like to use one towel for the first pass and then take another for the final pass, the way you won't get any streaking.
Awhile ago I had ordered some towels from Pakshak and I've been really happy with them. HOWEVER, since then, I've had the chance to try out the Superfly's from The Rag Shack and I like these a bit more. I just have so many of the Pakshak towels that I can't really justify get anymore microfibers right now or I'd be all over the Superflys. Besides, if I spend all my money on microfibers, how will I ever fund my addiction to LSPs? I have been itching to try out The Rag Shack Gladiator towel but again, I have plenty. The Gladiator as well as the **** Rag are on sale at The Rag Shack right now. I can get you a link to the PakShak towels if you want but I recommend the Superflys.
Haha. I re-read that and it confuses even me. Pakshak, rag shack, **** rag...
Awhile ago I had ordered some towels from Pakshak and I've been really happy with them. HOWEVER, since then, I've had the chance to try out the Superfly's from The Rag Shack and I like these a bit more. I just have so many of the Pakshak towels that I can't really justify get anymore microfibers right now or I'd be all over the Superflys. I have been itching to try out The Rag Shack Gladiator towel but again, I have plenty. The Gladiator as well as the **** Rag are on sale at The Rag Shack right now. I can get you a link to the PakShak towels if you want but I recommend the Superflys.
The superflys are all right, i use them for wiping polish and stuff off. They've also done good cleaning glass in my experience.
They're so cheap it's kind of hard not to like them
the reason that using a chamois or a water blade can be bad for the paint is the lack of nap. if there is type of dirt or contaminant left on the paint, it will get pulled across the paint, potentially causing damage.
the best, safest way to dry is to blot. blotting doesn't work with a chamois or a water blade.
