Cleaning/washing the engine bay
What I worry about is the computer and the cold air filter on my own vehicle.
I cover them with plastic grocery bags myself.
Some people worry about more.
Everyone has thier own way of doing things of course.
My procedure is:
Heavily spray down engine bay with Meg's APC+ dilluted 4:1
Let soak for a min or so
Hose down with high volume water (not high pressure)
Blow mostly dry with leaf blower
Run motor till nearly completely dry
Spray liberaly with Meg's HyperDressing dilluted 4:1
Mop up excess as best I can with Microfiber towel
Here is an example of a hard worked farm truck I detailed last fall
Engine hadn't been washed in over a year
Before
After
The rest of the vehicle can be found Here.
Hope this helps
My procedure is:
Before
After
Hope this helps
i may even try to cover those up
Be really careful under the hood. For every person that tells you they run down to the local "magic wand" car wash and blast away with no problems, you'll find one (like me) who refuses to play under the hood anymore. I used to, until I inadvertently caused all sorts of problems (even being careful and covering stuff) on my 2002. In fact, I politely refuse to do detailing work under the hood for customers for the very same reason. The best trick? Don't use a hose or anything that delivers either high pressure or high volume water.
I read, a long time ago, on one of these Ford forums about using a regular old can of scrubbing bubbles on the motor...
I first cover those critical electrical parts(battery, computer wires and such), as mentioned in previous posts, and then spray a whole can of the scrubbing bubbles onto the motor. After I let it sit for a bit, I get the garden hose and just let the stream of water(no pressure) rinse off the dirt and grime. As for the covered areas, I go over them carefully with just soap and water....very carefully. I also tend to dress the plastic areas with a little armor all...although I don't like that it eventually collects dust. :o
When I'm done, it's not necessarily showroom clean, but it's good enough for me.
Just my .02
Just my .02
