Easy soap dispenser
Easy soap dispenser
Check out the ortho dial n spray
It has an anti siphon dip tube which draws up soap vs. just water shooting into the cup and mixing it that way
The directions clearly state not to use soap in it, because that can clog to sprayer forever. Haven't had that issue however.
Walmart for $10.00 other versions out there.
time saver for sure.
I used Meguiar's® Gold Class™ Car Wash Shampoo & Conditioner since it was the cheapest quality soap I have on hand.
I mixed it 1 part soap (8 oz) to 1 part water (8 oz) because I was worried about the soap being too thick to siphon thru the sprayer.
Normally the mix in a bucket is 1 oz per gallon so I set the sprayer to mix and spray 2 oz of soap to a gallon of water since I diluted the soap by half.
Results:
This set up can be accurately described as a soap dispenser. It will give you a proper mix of water to soap directly on the vehicle so you could eliminate 1 bucket from the 2 bucket method but a foamer it is not.
Along with being a cheap good wash assist tool it was a good soap soaker to presoak and/or a mild touchless quick wash.
If you are careful this could be more efficient than using a bucket. Being careless will send loads of soap down the driveway/drain.
IMO it's a keeper. if it doesn't waste too much soap.
Anybody have any ideas to get it to make real foam?
Phonephotos
I was trying to make it work out to 1 oz per gallon but im going to drop it down to half an ounce per gallon today and see what happens.
That would also be very economical.
Question for Foam gun users...
From the experiment it seems that a foamer would use a lot of soap or more than 1 oz per gallon?
I was trying to figure out how to make the mixture foamier but your idea/suggestion is very sound as is.
Good free alternative.
Only drawback is that the sprayer is not easily to set down and keep upright and will leak quickly if not upright.
Ok. I'll try this again. I typed a reply earlier and then went to another page to check something and forgot to open a new window... post gone. So I just left.
I am currently using PBs Super Slick and Suds in the foam gun. For a normal wash, it calls for 1oz per every 2 gallons. Since the lowest setting on the foam gun is 1 oz per gallon (or 1/128) I cut the foam cun canister in half 1:1 wash soap to water and use the lowest setting. It's been working great. I've gotten about 4 washes out of it so far without refilling the canister and I can probably get another 2 out of it. I also use the 2 bucket method on top of that. Overkill? Maybe. Harmful? Not at all. I used to put just enough soap in the canister to cover the entire bottom of it which isn't very much at all. Then I would fill the rest with water and use the highest setting on the foam gun. The problem with this is that you really have no idea what the ratio is and you could be using too strong a solution and potentially stripping your LSP or you could be mixing it too weak and not be getting enough cleaning power and lubrication.
