Waxing at night
Waxing at night
Anyone ever wash, wax, and detail their truck at night? I'm leaving for a road trip this weekend and would like to the truck all shiney for the trip. I heard something once about waxing at night but for the life of me I don't see the issue. They said it will leave streak marks all over the vehicle. Anyone have any input? Thanks in advance.
I did most of my truck the other day, at night. I started at 3pm, but I didn't get finished until 2am, and even then I'm still not done.(still have hood and front bumper area to do, as well as going back over other areas I already did.) As JGJ mentioned, as long as you have good lighting, you're good to go.
Tomorrow I'll be finishing the truck off and it's supposed to rain. I'll be in the garage but part of the truck will be outside. When I need to the part of the truck that's outside I'll just spin it around and dry that part off before starting to work.
The products I use are designed to be used at 65 degrees and above. I even spoke with the chemist who actually makes the product and he said it was most effective above 65 degrees.
If its too cool or too humid, the products can and may not work as well. Being out of direct sunlight and 100 degree heat is great, but there is a range. You don't want it to be too cold or too hot.
I've detailed several cars in sub 65 degree weather and they didn't turn out as good as they could have if the weather was warmer. The product has its ideal application temperature just like anything else.
No adverse effects to doing it at night especially if you have good light. Hell the light may even provide enough heat to get the produce to set up correctly.
When this happens I always go over those areas with a damp microfiber the following AM when it warms up.
