I got my truck professionally detailed *pics*
Wheel wells take next to no time to do. It amazes me sometimes that people don't do them.
Truck looks good though.
From what I can tell the wheel wells look pretty clean but not shined.
If I was doing a full detail on a full size Screw (including buffing out several scratches) for $160.I would have found an area to skimp on a little bit too.
I would also like to see some close up pics to see how good they did at removing the scratches.
Use a garden sprayer to clean the engine bay. Once through with the cleaner (I use Simple Green 2:1), boar's hair brush, and then use the same sprayer to rinse. I can clean an entire engine spotless with less than 2 gallons of water. I have however blasted mine with a power washer as well and I have never had a problem.
Use a garden sprayer to clean the enging bay. Once through with the cleaner (I use Simple Green 2:1), boar's hair brush, and then use the same sprayer to rinse. I can clean an entire engine spotless with less than 2 gallons of water. I have however balsted mine with a power washer as well and I have never had a problem.
WOW!. The whole truck looks great especially the engine. Will have to remember that because I want to keep my motor clean as well. I will use some Simple Green and a garden sprayer on my hose. Coarse brush. Then wipe down as best I can. Probably do this 2 or 3 times a year.
I would say that was $160.00 well spent.
