Tips for removing old wax residue?
I waxed my truck a few months ago and idk what the deal was but the wax would not come off easily at all when I went to remove it. I was running out of time so I did what I could but now I have spots of wax all over my truck that I still needed to remove. I've tried using a claybar but it got me no were fast on the areas I tried. What should I do next to try and get this off?
Disregard the advice above from shotgunz. No need to do that and mess with very harmful chemicals and can harm other parts of your car like, wheels, rubber,paint etc. . If you do that procedure wrong you are in a world of hurt.
A few things you can try.
First try washing the car again and use Dawn to help strip the wax...this will remove "most" of the wax that is on the surface.
After the surface has been washed and dried, check the areas again, if you still see them, try using an ISP 50/50 wipe down on the surface...
(isopropyl alcohol mixed 50/50 with water.) Use like a QD.
If that still doesn't get it off, you are going to need to do a light polish with something like, Poorboys PP is one of the better polishes that has a cleaning agent in it..much like Megs DC Paint Cleaner.
If you don't have access to PB products, or want to wait you could use the Megs Paint/Cleaner. You can find that at most any big box retailer.
You will have no wax on the car left after you do this, but if you had problems with whatever you used, maybe it's also time to try something else.
Maybe a sealer for winter vs a wax.
Got any photos of these patches we could look at?
ValuGuard http://www.valugard.net/cms/xramp/Va...4/Default.aspx three step process
Gipraw and RollingRock: You guys are hilarious (ignorant, but still very funny). From the Motorcraft 2008 Lubricants and Chemicals catalog:
Acid Neutralizer
Features:
• Neutralizes acids which may have been deposited on the paint surface during transportation and storage
• Removes waxes and hard water spots
• Excellent pre-wash for body shop - removes silicones, waxes and other contaminants before sanding
Just because you never heard of or tried the process, it must be "bad".
Acid Neutralizer
Features:
Acid Neutralizer
Features:
Acid Neutralizer
Features:
Ignorant? Give me a freaking break. Where did I ever say I had never heard of the process? where did I say I had never used the process? I didn't say I didn't know what you were talking about. I said you were wrong for suggesting it.
I will match resumes with you any day of the week, dude. you have NO idea what the hell you are talking about. You are giving bad advice to people.
In this instance you are recommending someone hit a problem with a hammer when it can be addressed with a q-tip.
Do you have any detailing experience at all? Show us something you have done. Or even better .. show us something that you have taken care of exclusively for years that still looks perfect.
I normally try and be nice to people, even people that I disagree with. But since you already called me ignorant, I do not feel the need to do so.
You have NO idea what the hell you are talking about here. The process you are suggesting, while it will work, is way overkill for this particular problem, and you are either too inexperienced, or too stupid to understand that.
Suggesting this process for removing dried wax off a vehicle. How stupid can you be?
I don't give a crap what you think of me .. but I will tell you something ..
Come back and call me ignorant once you have something that even approaches my experience. Until then, try learning a little something.. going through life closed minded and stupid is a hard thing to do.
I'm sorry I called you ignorant.
I responded incorrectly to your compliment.
I must have missed the post where you offered your expert advice to the OP.
With all your experience, I'm surprised you didn't tell him to using polishing compound or 1000 grit sandpaper. After all, the claybar didn't work - time for the REALLY BIG GUNS.
Please explain where you have used the neutralization process and why it is the wrong choice to remove wax that has been on the vehicle for months. I'm all ears.
![bows](https://www.f150online.com/forums/images/smilies/bows.gif)
I saw no need to reply to him, as RollingRock had already given some very good advice.
I will say it again. Show us something you have done. Show us something, anything that would demonstrate you have any ability to do anything other than offer bad advice.
As I already said. your way will work, but it should not be the first tool out of the bag, especially for a weekend, driveway detailer.
One thing I didn't mention to the OP is that a lot of times, simply going back over the area with a good QD and and HQ MF will take care of the problem.
LovetheTide,
I want to say it was Mothers California Gold maybe? It came in a red tin container. I've used this stuff before and it came of wayyy easier than it did this time. Next time I'll be using the #21 I've got.
![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
Do you ever come into the Fort Worth area? I'm going to be there around the 11th and was going to see if anybody wanted to meet up and snap some pics or something.
Yea I had used this can of it before and never had any problems. Just a regular microfiber towel. Not a waffle weave one.
Will do man, thanks. Hopefully they can take care of things against UF and then we can focus on a Nat'l Championship.![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
Send me a pm or visit the cafe to find me! If you want me to take a look at your truck during that time you could come on over to Keller, short drive.
Cheers
RR
