Cleaning tires???
Do not use Meg's Super Degreaser if you have uncoated aluminum wheels! It will stain the wheels when it runs down off of the tires. Other than that it works fantastic. Meg's All Purpose Cleaner 4:1 works well also and doesn't cause any harm to the wheels.
Yes, good point. That could be said about the other two as well, the Eagle One definitely as well. Another tip is to wet the surrounding panels with some soapy water so if some overspray does occur, it doesn't stain the paint.
I only mentioned it because I made the mistake of using Super Degreaser on my tires, well one of them. That's all it took for me to learn. I've never used the other two near aftermarket wheels to know. And now I never will.
Oh yeah, I hear you! I've done it before as well; with Super Degreaser and Wheel Brightener. The soapy water does the trick in case you need something besides soap and water to clean them. I just scrubbed the tires today with Purple Cleaner full strength, after washing but not rinsing the polished wheels with soapy water first. All is well!
