exterior black plastic????
Old 03-19-2010, 03:35 PM
2002f1504x2's Avatar
Question exterior black plastic????
what can i put on the black plastic on the outside of the truck mirror caps front bumper bed rails ect.. to keep them dark black and clean looking..will armour all work?..my main focus is finding something that will not leave streaks and run down the side of my truck in the rain..anyone know anything that works??
thanks
Old 03-19-2010, 04:33 PM
dsq3973's Avatar
There are quite a few products out there that will work. Here are just a couple that work well for some of the people on here.
Megs Hyperdressing
Black Wow
Aerospace 303
Old 03-19-2010, 04:38 PM
roushstage2's Avatar
Not running in the rain limits it to two products that I know of:
BlackWOW
Meguiar's Ultimate Protectant
Old 03-19-2010, 04:46 PM
dsq3973's Avatar
If you do Hyperdressing right it wont run in the rain. That is all I use and I have never had a problem.
Old 03-19-2010, 05:52 PM
clambelly's Avatar
have you looked past what you have posted? There currently three active threads addressing plastic rails, black plastic, black wow, etc., plus many that a search would produce.
Old 03-19-2010, 08:14 PM
dsq3973's Avatar
Are you refering to me or the OP?
Old 03-20-2010, 05:16 AM
glc is offline
BlackWOW
I did my bed rails with Megs and it ran.
Old 03-20-2010, 05:30 AM
ELVATO's Avatar
UP runs? Figured it wouldn't since it's not water based, right? My friend hasn't had any running issues, but then again, his car is silver, so it might not show?
Old 03-20-2010, 07:10 AM
clambelly's Avatar
Not you, Dave
I sorry I caused a misunderstanding, I should've quoted the OP
Old 03-20-2010, 08:15 AM
dsq3973's Avatar
Not you, Dave
No problem.
Old 03-20-2010, 01:29 PM
glc is offline
UP did a fantastic job on my soft tonneau because it soaks in. There's nothing to soak in on the bed rails. It's darn good stuff but everything has its limitations. I was told a good way to keep it from running after use on hard plastic may be to wipe it down with QD on a microfiber after application.
Old 03-20-2010, 08:17 PM
SPARKY357's Avatar
Aerospace 303 is my vote. This can be bought at any West marine store. Its made for boats. I have used it for years with no issues. It leaves armour products in the dust. Hope this helps.
Old 03-22-2010, 12:11 AM
That's the only way I could see HD not running as well, especially being a water based product. It shouldn't run on "regular" trim pieces, I guess you could call them, like the cowl and mirrors and such though.
Old 03-22-2010, 01:09 AM
i know i can get black wow for about 24 bucks a bottle and im gonna have to look around for the 303..best thing to do is buy them both and give them a test run i guess..303 is getting the fisrt go round cause its about 10 bucks cheaper..thanks for the input guys i appreciate it
Old 03-23-2010, 06:04 PM
F150RYDER2K8's Avatar
I use Turtle Wax Ice Clear Liquid Polish. You can use it on Paint, Plastic and rubber molding surfaces. It goes on real easy, can be applied in direct sunlight and leaves an awesome shine on your paint and brightens all that black plastic and rubber moldings. I never put Armorall on that Black Plastic because I have found the Armorall fades it over time.
Quick Reply: exterior black plastic????
