Megs Scratch X the whole truck
Yeah if you do the whole truck by hand it's going to be a long job. Scratch X works but if you've got bird etchings it may take a few passes. If by hand I'd say just do the worst spots now and save up for a polisher. Or buy a polisher now to do the whole thing.
Or if you already have a polisher then I'd say you're good to go! Yes, always follow up paint correction with a fresh coat of wax.
How about you take it to the guy that did your detail last year?
If you are going to do it by hand, wash and clay it, then you can use the new Megs polishing compound that's designed for hand application.
http://www.meguiarsdirect.com/detail/MEG+G18110
If you can't find it, you can use Megs Ultimate Compound. Either way, it's going to be a lot less work than using ScratchX on the whole truck. Then you can finish with NXT. ScratchX is designed for spot application only.
