Help me get that red dot off my tires!
I use brake cleaner and an old rag. Spray the cleaner onto the rag and give it a rub or two and it should come right off..
Well, 'Dot' isn't a very descriptive term.
If it's as small as a pea and not noticable at a few feet then I agree it's not serious.
However, if the Dot is as big as a quarter then at thirty or so mph it could easily give the impression one was riding around on red walls.
And anybody riding on red walls is just putting on airs, plain and simple.
Some general information on dots...
These are guides to technicians in mounting tires so that aligning the red mark with the low spot on the wheel(usually marked on wheel with white dot) is the best method for mounting tires.
Link to info
Link to info
