Took the Plunge
My I tried several headlight restoration kits but liked this one the best but now I just use M105, small pads and the DA. It's MUCH cheaper in the long run. I also find that sanding and then polishing the sanding marks is about as much work as just using the DA heavy cutting pads (4" maroon) and a final polish with white or black 4" pads but my fingers feel better & are cleaner when im done. I have a high speed, high torque drill but im worried about the vibrations breaking the element in the headlight bulb...again.
Good luck & be careful...the detailing rabbit hole is very deep.
