clay sticking to paint
You are referring to Meg's Clay Bar? I used a Meg's Clay Bar on my '02 GT a few months ago in 100+* heat index, I just kept it lubricated and had no issues. I always take the clay bar and kneed it several minutes before the first use.
Try running water over the area while using the clay bar. The water will keep it cool. Also, I always squirt a little detailer on the clay bar before beginning the process.
You may be pushing on the clay to hard. Only time ive had that problem was pushing to hard on it or the QD was drying up to quick and not allowing it to be slick enough
I must have been pushing too hard. I dropped that last 1/2 of clay, so that's that. I'll go easy with a new bar tomorrow,
Was the truck outside/in the sun? If the paint is hot clay will definitely stick to it. Clay will also sometimes stick if the paint has a lot of silicone on the surface (normally from certain waxes/excess auto car washes).
As mentioned, your best bet is to keep the paint cool if possible (it doesn't need to be inside, just cool to the touch). If it continues to stick perhaps try stripping any wax you have on there prior to claying.
What are you using as a lubricant?
Besides using enough QD for lubricant it helps to QD the entire car prior to claying. By doing that you are getting some contaminants that the wash missed first, leaving that much less for the clay to pick up. That and your clay bar will last longer.
You should be spraying enough QD on while claying so that your almost splashing it around. No need to press hard just nice easy strokes, keep your work area fairly small, 1/3rd of the hood for example then wipe dry/continue.
