A simple and silly question.
I noticed that my left turn signal is going hokey. It clicks and flashes really fast. I am guessing my blinker controller is going. Here is the silly part. Does the blinker controller control both blinkers or just one? It only does this on left turns, I use the right one for the other left turns.
Erik
etimmer@Pharmacy.Arizona.EDU
97 150 XLT 4.6L V8
K&N Filter
Vel. Tube (soon)
My Web Page (not much here)
Erik
97 150 XLT 4.6L V8
K&N Filter
Vel. Tube (soon)
Unless something has changed in the way that blinkers work -- a fast blinker means there is too MUCH current going thru it -- whereas a burnt out bulb would not draw enough current to make it blink.
Common causes for a quickie-blinkie include a botched tap-in for trailer lights.
"HD" blinkers are designed so that they are current in-sensitive -- so that it matters little how many bulbs are on the circuit -- which allows for an additional trailer bulb (each) but takes away from the bulb-out-no-blinkie feature.
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Actually, it can cause a short when one of the filament burns out in a dual filament bulb... the broken filament can sometimes dangle against the other filament and cause it to blinky fast. It's possible, so start there. It's the elementary solution. Next, move to the flasher. HD flashers are just that... HD. They will blink a bit slower without a trailer, but will be normal with the extra load of a trailer. However, on most Fords with the Factory trailer towing package, there is already a trailer light converter that runs the trailer lights off an entirely separate circuit... prevents the rapid flash caused by the extra current through the flasher, and prevents shorting the vehicle's lighting if there's a short in the trailer's system. You can buy a special electronic flasher to replace the bi-metallic one, but like he said above... it flashes the same speed regardless of how many bulbs there are on the circuit (or how many there aren't!)
-Joe-
98 Explorer (Lemon Law Case in Progress)
Deposit on '00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Sunroof, currently missing the fuel filler door, but they're working on that..
-Joe-
Ya,
I checked that after I checked the brake belts. You know, behind the Power Driver Seat spark plug.
Weeeeeee! This is getting silly.
Erik
97 150 XLT 4.6L V8
K&N Filter
Vel. Tube (soon)
Erik
97 150 XLT 4.6L V8
K&N Filter
Vel. Tube (soon)
Location: Houston, by way of every major city in America.
on
Had that problem on a few cars,it was always a burned out bulb or a bad flasher
good luck,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Clear Euro tails(Altezza style)
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper 500HF Security system
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
www.my-f150.com .still want to lift it,YES!
Fender Guitars,ROCK!!!
http://www.bigsandy.net
officialtomwaits.com
reverendhortonheat.com
good luck,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
