steel wool
0000 (very very fine) steel wool is perfectly safe to use on glass only (no tinting). I have used it for years on every vehicle I have owned to get the 'Bug Juice' off. Also..never use it on any type of plastic, there are other products for that.
OP never stated his purpose for using it but steel wool's primary function is mechanical surface removal (metal sanding).
If you use it wrong or long enough lube or not it will dull the smooth surface of the glass. IMHO...Thats not perfectly safe.
For hard water spots I would use a razor blade and vinegar or window cleaner before steel wool.
Jetech, do you work on Jets?
