Help with cleaning chrome wheels
What is the best stuff for cleaning chrome wheels? I have 20in chrome wheels that get killed in the winter. I spent several hours on them last year after winter and they never did look that good. None of the cleaning stuff i got worked. So please let me know of anything that would get the crap off my wheels. What do detail shops use?
Best bet....soap and water. I clean mine well during each wash. In between washes, I hit them with Poorboy's Spray & Wipe after hosing them down with the wand. 1 to 2 times per year, I polish them....currently using Optimum Metal Polish and a Mother's Power Cone for that.
Might want to try this as well for the deep cleanings. I just got one but haven't used it yet....too darn cold outside:
http://www.obsessivedetail.com/Ezdetailbrush.html
I would check out Sonax Full Effect Wheel Cleaner. It's very strong but safe on ALL wheel finishes. That along with a Daytona Speed Master Wheel Brush is the perfect combo for cleaning dirty, neglected wheels.
FWIW, heres a bit of info on our stuff:
Adam's GREEN Wheel Cleaner is a 100% water-based cleaner that safely and effectively cleans tires and all types of wheels!
Adam's GREEN Wheel Cleaner takes advantage of new breakthroughs in chemical engineering, creating a new class of non-ionic cleaner that does not release harmful zwitterions. Adam's GREEN Wheel Cleaner quickly and safely cleans tires and all types of wheels including clear coated, painted, aluminum, polished and anodized. The active ingredient in this cleaner was developed in America to replace the acids, and butyl ethers found in most tire and wheel cleaning products, which have been proven harmful to both wheels and nature.
It's an unfortunate fact that most wheel cleaners made and sold in America contain butyl or butyl ether. Although butyl is a highly effective cleaner, as well as inexpensive, it is harmful to man and the environment. Plus, butyl will white-stain aluminum and damage clear coated wheels and powder coating finishes. Butyl is also very harsh on your skin, causes respiratory distress when inhaled, and it is not readily biodegradable. Our Green Wheel Cleaner contains no butyl or petroleum distillates! Plus, our new GREEN Wheel Cleaner biodegrades 98% in less than 24 hours, protecting our surface waters from polluted storm drain runoff.
BEFORE:
AFTER:
*special thanks to Jim (Nordgrey) for the great pictures.
BEFORE:
AFTER:
I've been following this thread just becuase I'm completely OCD about my chrome rims. First thing I did for proactive maintenance....change my brake pads. I now have Wagner Thermoquiet ceramics on the front. Makes a HUGE difference. I've also noticed that using a spray detailer at least once per week in b/w washes not only does a great job....it almost eliminates the discoloration I was experiencing that only polish would remove. Now I'm only needing to polish once per year. Again, I use Optimum Opti-Seal for a sealant...just b/c I hate having to remove wax by hand.
For cleaning, any "specialty" product, i.e. wheel cleaner from Adams or Poorboys, etc. will work. Some of the shelf products work well as well. Personally, I don't like to use agressive chemicals on my wheels; I stick to soap, water, and a good brush....followed up with a spray detailer..then sealant. However, if it's caked on real good, you'll need something more agressive.
Done ranting......good luck with your wheels.
Good point... and I'm with you 100% sealing the wheels regularly to keep them protected makes them MUCH easier to keep clean... so much so that as long as I stay on top of the sealant application on my wheels a simple soap and water cleaning (ph neutral cleaner so as not to degrade the sealant) is all it takes.
In some cases after sealing all it takes to knock the grime off is a strong blast from the hose.
Nice wheels btw.
Nice wheels btw.
LOL... commonly asked question - it does sound like a made up word I'll admit.
Its essentially a dual charged particle, or in other words it carries a positive and a negative electrical charge within one molecule. Basically thats a fancy way of classifying them... they're most commonly seen in small concentrations in very aggressive cleaners as surfactants. In a wheel cleaning scenario specifically they're not good as they can haze or discolor aluminum... I believe (and I may be wrong here) they are alkaline.
