Headlights
Headlights
I got a pair of Harley headlights today and the driver side has a nice little scuff mark on it. I was reading some threads that are a bit dated regarding headlight restoration. The lights themselves look pretty decent as far as clearness goes..... just the darn scuff mark looks bad.
So... the question is.... Are you guys still suggesting PlastX or has something new become available?
- wetsanding
- M105 with a cutting pad
- M205 with a finishing pad
- THEN some Plast-X
You're right....I think sanding is better for discoloration, etc. For a scuff....some polish and/or PlastX might be best.
I'd start out with a little PlastX on a MF towel by hand, and see what it does, if that doesn't get you to where you want to be, then step up a little from there.
I did this in less than 10 minutes (taping time included) with the following process:
Meg's 105 on a cutting pad on a Flex
Meg's 205 on a finish pad with a Flex
PlastX
PlastX
![](http://www.thedetailerscafe.com/smf/gallery/2/32_31_01_11_8_32_39.jpeg)
Gipraw... what a difference! I haven't had much time to mess with the lights I got last week but I did (didn't expect much) use some Dupont #7 polishing compound on the scuffed area, but not much improvement. The scuff mark seems to more than just a surface scuff so some wet sanding will be necessary. I am away from home till Friday, so I am hoping to get to them this weekend
