Clay bar
Clay bar
I've seen alot of you folks referencing the use of a clay bar to prep the surface of the paint. WHAT IS IT......I have never heard of this item. Is it like a polishing compound? How do you use it? I'm getting ready to put down my first coat of wax on my baby this week and I want to do things right.
Don
2001 F150 SC 2X4
Arizona Beige
Short Box
5.4L
3.55 LS
Captain's Chairs
Power Seats
Sliding Rear Window
Tow Package
Herculiner Bed-liner
Bug Shield
Hard ARE Tonnaeu Cover
1.01 soon to be 1.42 Radiator
[This message has been edited by dnaber (edited 06-18-2001).]
Don
2001 F150 SC 2X4
Arizona Beige
Short Box
5.4L
3.55 LS
Captain's Chairs
Power Seats
Sliding Rear Window
Tow Package
Bug Shield
Try this, dnaber.
http://www.erazer.com/
Nice info on paint contamination and about how clay's work. I use the erazer product and like it, but there are other brands out there.
I keep my truck washed and waxed regularly and I only need to use the clay maybe every other time I wash. If you're keeping your ride clean, it's nothing you're going to need to use a great deal. I'm always checking my hood with the back of my fingers to see if there are any "splinters"....meaning it's time to clay.
01 Black SuperCrew 5.4; Airaid, Borla Split Rear, Line-X, Matched Tint windows. Black. Black. All Black.
Blaupunkt "Munchen" HU; JL Audio Stealthbox, DiamondAudio M551 components, Kicker Impulse coax (rear), RF250a and Kicker 350xi amps
When you bought your baby did you see the white cars on the dealers lot with nasty black soot all over the paint? Well that road and rail grime is embedded into the paint. Just as it is very visible on white trucks it equally blemishes black paint. Washing and most cleaner waxes will not remove it completely. That is where clay bar products come in. Clay bar is a micro-fine cleansing bar that must be used properly with lubricant to remove this crud. Much like a jewelers' rouge.
After claybar proper polishes are a must.
I've use all kinds and without question the finest, easiest to use and most economical are Zaino products. www.zainobros.com
Sal's website will educate the unknowing on just how to polish a car for the show class.
I used these products exclusively on my Corvette C5 with fantastic results.
I don't sell the stuff but I'm picking up a fresh supply to clean up my new Supercrew the weekend.
I posted on clay bars last year sometime. I used one on my truck and wife's black Miata. It worked GREAT!!!!!!! I recommend using one PER vehicle. It was wasted mid way through the car. Luckily, I used to detail cars, so I got a high speed buffer and orbital buffer recently, and use them. I high speed them both once a year and use the orbital to wax them 2 or 3 times a year. HJere in FL, the wax doesn't last terribly long with the heat. I use nothing but Meguire's wax and buffing compounds.
Slapshot.
Just curious, what do you mean by "wasted"? When I was detailing 2-3 cars per weekend I could get a clay bar to last about six months before it started to lose consistency; about the only thing I did to it was wipe it off after every section of the car I was doing (door, hood, etc.) and then clean it before I put it away.
