Flex 3401 and LC 1 Pad kit Usage
on
Wanted to see if anyone else has confirmed this.
I am in the market for a new DA polisher ( antique PC is on its last legs ) and I was looking at the Flex 3401 DA polisher.
Thing is best I can tell from the part diagram and the literature on the 3401, the backing plates are specific to the Flex item and the Lake County 1 pad kit will not work on it.
The Flex backing plates are held on with a Allen head bolt through the face of the backing plate, and the attachment to the 3401 seems to be a cog wheel ( marketing material indicates this is what held reduce the vibration ).
Want to make sure of this before purchasing a 3401 ( or not buying one from what might be a misunderstanding on my part ) if the 1 pad kit backing plate will or won't work on the 3401.
Sounds like you got a lot of miles on the 'ole PC.
Have you considered graduating to a rotary?
The Flex 3401 DA - $319
The Flex 3403 Rotary - $239
I recently purchased a Flex PE-14 - $379 (only a few bucks more than a 3401) and I've never looked back.
Using a rotary...
For "heavy" correction you can use wool pads. I use the Lake Country Kompressor Purple Heavy Cutting Foam Pad and it works great!
I can use my existing collection of 4", 5.5" and 6.5" pads as well as 7.5" pads.
For "jeweling" this is where a rotary truly shines (pun intended) IMHO using a rotary with a LC blue pad at 600 rpm makes an outstanding finish!
BTW - Did I mention that it now takes me about 1/3rd the time it took using only a DA?
On the other hand, the Griot's Garage 6 inch Random Orbital Polisher - $129 has a LOT more power than the PC.
You can use your existing pads and it will work with the Meguiars 5 Inch DA Microfiber Correction System.
What are your thoughts?
