Sliding rear window leak
I just signed on and was not surprised to see a list of similar problems. It has been raining for about a week now and my back seat smells like a wet dog! Ford looked at it after a glass business referred me and stated that it is a Ford problem. They have seen a lot of them and if they fix it right is is $650 for the new design. Ford Svc mgr states that yes, it is a problem, and yes Ford has re-designed, but no, there is not a recall or service bulletin. Ford svc did say that they would "help" be even though I have 55K miles. That was 10 days ago and no word back from Ford, other than they are ordering a new replacement rear window unit......my cost is unknown....but I didn't sign anything authorizing the order. Hmmmm. I do that a Ford board of directors member has a plantation retreat in this area.....I wounder if he could help!
Actually, there IS a service bulletin (Article No. 01-1-11 on Alldata, 01111 at NHTSA). Note that a service bulletin is not a recall and does not require the dealer to cut you a deal.
According to the bulletin, it is not always necessary to replace the entire window module. Hopefully, your dealer inspected your window first, and did not just assume that a new window was necessary.
At any rate, $650 seems high. I haven't shopped around yet, but my first inclination is to go to an aftermarket glass shop and buy a new installed window for much less than $650.
It's funny the things you learn about after you buy a vehicle. So far, I've learned about door cracks and leaky rear windows.
Also, if you've just bought a used truck, you can check out the Ford web site to see if there are any outstanding recalls on it (sorry, I don't remember exactly how I found it, but it's there.)
