What do you use for interior plastic?
I use either Lexol or 303 products on plastic and rubber.
search some old posts, I believe the most important step is getting the pieces cleaned and prepped for the paint to stick. I've used Duplicolor Interior Vinyl and Plastic spray dye on door panels after wiping everything with paint prep solvent and it sticks well. only been a year so I have to see what the sun does to it.
back in the 70's when armor all 1st arrived its formula was very different....if you kept applying it- all was good, if you stopped for 6 months +....whatever it touched cracked 7 rotted....they were sued in a nationwide class action......in the department I worked in at the time, maintenance issued it out for every pices of apparatus in the department 930+ units IIRR)...a year later...every piece of upholstery & padded dash was destroyed....Armor did pay to have everything replaced. It disappeared from the market for about a year, then came back with a completely different formula.
I personally use a product called "Prime-Shine" for the padded dashes, etc.
