loose rubber trim/gasket on roof
Rubber seal around back glass
This is a common problem. I noticed this on my truck and it does not affect the waterproof of the glass assembly. This falls into the category of "Leave it alone, the cure may be worse than the problem" If you have the dealer repair this seal, it's hard to tell what may end up getting scratched or dented. The cosmetic appearance is also unaffected. I just removed mine completely and it looks just as good.
leak in back window
bluemesa159----- The leak you have is not caused my that little rubber seal being defective. It may be caused because of the window design. There are many posts here concerning leaky back windows on 99 f-150 trucks and the repair solution is to install a 2000 window design. Check the search feature here and I think FOMOCO is replacing 99 back windows under warranty. Regardless that little seal is for cosmetic purposes only. I held a garden hose on mine for 5 min and no leaks and my seal was removed
