Rust "Dots" on Body
Rust "Dots" on Body
I have read all the posts about the rust on the inside of the doors and the tailgate, but I am concerned about some very tiny "dots" of rust forming on the lower portion of my truck body and tailgate. I didn't notice them at all until I was down there waxing by hand. They are that tiny. But they are everywhere! Does anyone have some advice on how to a) fix this quick before its a problem b) prevent it from happening again? Thanks!
Rail and brake dust?
Could be rail and brake dust that has embedded itself in your paint. You could try using a clay bar to remove it. Most paint care mfgs. have clay bar products. Try doing a search on it, there is a ton of info here on how-to 's and such...
I clay bar my truck once or twice a year before cleaning, polish, and waxing.
I had the same problem this spring with my truck. I know a guy who owns a body shop and he gave me a really fine rubbing compound to use. I wish I could remember the name of the stuff so I could tell you what I used. It worked great; all I had to do was rub it gently over the affected area and then wipe it off. Afterwards I waxed the whole truck. These spots really stood out on white, but I'm sure that they would be noticeable on other colors as well.
I hope I don't have to do it all again next spring.
Actually Ferrous Oxide particles
Ford issued a bulletin to all the dealers on this, #99-12-10. It is still in effect, and now included in all new shop manuals the dealers get.
They will pay for the treatment specified in the TSB for the first 12 months or 12,000 miles under Enviormental damage as stated in the owners manual.
You can see and print it out, shows the why they spec the process, what happens if you use clay or compounds, etc.
Even gives the time allowances for the dealer's warranty repair time.
You can find it at www.autoint.com under the OEM/TSB section of the site, look for the first part of the section.
