Gettin the mud off the motor!
Just curious as you what people are doing to clean muck off their motors after some serious wheeling.
Are most using a pressure washer? Garden hose? any detergents like simple green? My motor isn't greasy, just need to get rid of all the brown!
Thanks in advance,
Bambino
Thanks in advance,
Bambino
Bambino,
Have you tried castrol superclean? I use professional stuff nowadays, but I used to have good luck with the Castrol. I never really had mud under the hood per se, but I did often have it on my supension and fenderwells. I only used a garden hose, but if you have a pressure washer, I'm sure that would be even better. The important thing to make it look good is to dress your plastic and rubber parts afterwards. Ancient Chinese secret: WD40. It works very well to black out your engine. Spray it on and wipe off the excess!
Good luck!
Good luck!
