Need help w/ Zaino
Need help w/ Zaino
I have had a few problems with Zaino. After applying the Polish Lok (1) to the clean car. I let it dry and then applied polish (2) with damp applicator. I allowed this to dry for a few hours. Then took 100% cotton towel Made IN USA and began to wipe off the polish. It seemed to only smear though and leave streaks...it did not turn in to the powder I expected it to. (The car was inside so weather really couldn't have been problem) What could i be doing wrong? Are the 2001 Harley Clearcoats? Thanks for any help you can provide.
I apply the Z2 with a different applicator than I used for the Z1. I use a dry applicator for the Z2.
It sounds like your Z2 didn't dry. One hour is a baseline for the drying of Z2. If it'c cooler, more time, if the air is humid, even more time. If you let your sit for a couple of hours, I can't imagine why it didn't dry.
I've never seen that problem. I would encourage you to email Sal Zaino at Zaino Brothers.
I agree with the suggestion above that it sounds like the Z-2 didn't dry completely, but I'm not sure why. Sal may be able to give you some other things to check before taking off the Z-2.
Good luck. Sal's email is Sal Zaino @ Zaino Brothers
Zaino is VERY susceptible to the conditions of the air. The first time I used Zaino in April, I too, was not satisfied with the way it came off -- It left a nasty smear.
The problem is that you didn't allow it to dry completely, which is KEY to getting a good finished look. It may take up to 1/2 day for the polish to dry, but the results are well worth it.
I found that the temperature needs to be AT LEAST 70 degrees if you expect the polish to dry within 2 hours. If it's 60 outside, then it may take 5-6 hours to dry, depending on the humidity.
Another tip is to use a very LIGHT coat. 3/4 bottle of Z-5 has lasted me about 8 coats on my SuperCab. Use it very sparingly.
