chrome exhaust tips
chrome exhaust tips
is it ok to use something like Turtle wax on your exhaust tips???? I just got some duals put on my beast last week and the tips are 22" long. I don't like Chrome poilsh because of the abrasives in it. If it's ok to use the wax, maybe like once a month should be sufficient??????
Wax won't last the drive down the block. Wax's melting point is around 150 degrees. Depends on the wax, How much carnauba vs. how much beeswax or parafin is in it.
Your exhaust tips get a lot hotter than that and will simply cook it off. If it is chrome then you are going to have to use a polish to keep them shiny. I'm not even sure if a synthetic could stand up to the heat.
Originally posted by f-150_91
so find a good tough polish maybe like Meguiars Step 1 Deep Crystal polish????????. If this is not good to use maybe you or someone have some suggestions, I want to keep them lookin pretty!!!!!!!!!!!
I personally use Blue Magic Metal Polish Cream. It is for Chrome, Aluminum, and Mag Wheels. I use it on my chrome nerf bars and it leaves behind a protective coating of some sort. You can tell a difference in the way the water beads off them when I have a fresh coat on them. I also use this stuff on a brass belt buckle and it didn't start showing tarnish for several weeks. Before it would show tarnish the next day!
I have tried all the aluminum and chrome polished blue magic and mothers and by far the best one is Wenol it is great. It does a much better job than the others.
Wenol Polish
Wenol Polish
Re: which one?
Originally posted by TexfordD
eagle one never dull wadding polish...has the wadding in the polish,all you need is one of mamas show towels from the bath room to bring a nice shine to the tips or your eye if mama finds out first
