Rear Window leaking on 1999 F-150
Check to see if you weather seal has receded down below
the trim. I've noticed alot of them has, including mine.
I talked to two dealers already. One didn't want to fix it
because they said they replaced one trucks three times now
with the same result. They said ford was working on a
fix. The other dealer had no knowledge of that. Just my
2 cents.
2 cents.
Service Bulletin Number # 01111
Bulletin Sequence Number # 180
Date of Bulletin posted 01/01
I have a 1999 Lariat and had mine replaced back in 2001, Feb. I think. Now once again the seal, the black foam bead that shinks has fallen down behind the rear window halo, tell the dealer you want the new 2001-2002 Supercrew rear halo, they have a very nice, thick real rubber not foam seal that wraps around the edge of the halo.
I am getting mine replaced for the second time after 60,000 miles under warranty, but I also have Premium Care warranty too!
Showya
Showya
I noticed that black seal started to pop out alittle around the drivers side, and sink in on the passenger side. Its not leaking, but i asked my dealer to replace it and its on order. It will be the new design like the 02's have where the seal like attaches to the plastic or overlaps. It looks ALOT nicer. I'll get pics for you's later. good luck
