FIPK Question
FIPK Question
Living in MN we have some very unusual climate and weather changes. Take for instance this week 90 on Mon & 35 and icy on Wed??? Having an open filter with an FIPK, will these be affected by changing conditions, cold temps, snow & rain in the summmer? Are there chances of snow & rain ingestion through the filter more so than with the stock set up? Will wreck it anything?
Thanks for any advice
By the way this would be going on a '01 off-road Screw with the 5.4.
Hi sxmax,
You have nothing to worry about there, as your engine has an IAT (inlet air temperature) sensor, and the PCM commands different operational parameters based on that, as well as many other things such as engine coolant temperature, automatic transmission fluid temperature, etc.
The factory air intake tract is very restrictive and doesn't need to be. As you can see in Habibi's post, his truck is wearing the best intake kit, which is the Air Force One (FIPK is actually K&N's name for their intake kit). That AF1 intake is *beautiful* under the hood, that's a very nice picture Habibi took.
Now if you were using an aftermarket hood with open air scoops, etc., *then* you might potentially have an issue in the rain with water getting onto the air filter element, but even that is easily cured.
The bottom line is you'll be fine with an intake kit in any weather with the stock factory hood!
