Mike, comment?
Mike, comment?
Mike, any comment on this?
https://www.f150online.com/forums/sh...hreadid=121476
Kinda has me worried :o
Hi '03,
Yes, I have a comment - in a word, BS.
It is *not* true that using a low-restriction exhaust raises exhaust gas temperatures, or cylinder head temperatures, etc. In fact, it does just the *opposite*, it lowers them, if any change at all.
For years we have advised PSD (Powerstoke diesel) owners to open up the intake & exhaust to reduce restriction & let the motor breathe, to help lower EGT's when running performance programs & towing heavy loads, etc. Why? Because doing so *lowers* the EGT's & cylinder head temps.
The claim of reduced flow thru the EGR is false as well, at least when we're talking about normal brand name cat-back exhaust systems, CARB-approved headers, etc., that's absolute horse-hockey. That can only happen if you deliberately alter the **EGR system,** disable it, etc., and that does *not* happen with any cat-back exhaust system or CARB-certified headers that we carry, or that I am personally aware of.
You'll note that one of the things said is that what they're really looking for is to see if the *emissions* systems have been tampered with, and *that* is the key. It has nothing to do with a proper cat-back low-restriction exhaust system, or even headers that are properly designed, *none* of those components (at least, among quality manufacturers and including *all* the parts we carry) modifies the EGR system.
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
