Micro tuner question
Hi Uh,
The Micro Tuner changes nothing with regard to the function of the transmission selector switch (the Overdrive button) on the end of your shift lever. As jaymz correctly mentioned in his post, with the Micro Tuner installed you just operate the vehicle as you normally would, so it doesn't matter if you use Overdrive or not, that is strictly up to you. Most people just leave the O/D on unless they're towing, for example.
If you'd like to go over any of this (or anything else performance-related about your vehicle) in more detail, feel free to give us a call at our number listed below.
