super chip w/5.4 5 spd?
Hutch: when is your new crew-cab to arrive?? Did you use your 97 as a trade? And the really big question: How much??? Did you order the 5speed?? What color?? Which seats? Was your 97 a 5 speed? If you have ordered the 5speed, when you do get it, please post how it runs & how you like it Your question about what bennies you will get from the chip is a Mike question for sure. I haven't seen anyone posting here with a 5speed 5.4 Maybe check the F250 thread, might be more info there.
97F150 XLT SC 4x4 Flairside 4.6 V8 5sp Dk Toreador Red, 3.55LS
ARE tonneau cover, p255/70rx16 tires (came w/235), Superchip
Pioneer CD w/4 Polk Speakers & Clarion APA5240amp, skid plates
bed liner, side window deflectors, reese hitch, K&N air filter
40s-2chamber Flowmaster, Bosch +4 spark plugs, rustproofing
Better Built Stainless nerf bars
Thanks Tina. The 250's due sometime in mid Nov. Always been partial to Black/Tan...150 was the same. Trading it unless I sell it before the new one comes in. As far as $$$$ I really can't complain. I get it on the "Z" plan since my father was a retiree.... works out to 4-5% below invoice. "it's a good thing"!
current: '97 F-150 ext cab 4x4.
ordered: '00 F-250 crew cab 4x4
Dear Hutch,
So far, the 2000's have been responding with approximately the same gains as the 97-99 F-150's have. So you can expect about 28 horsepower, and 46 lbs./ft. of torque from installing the Superchip on a 5.4 engine, whether you have an automatic or a manual transmission.
What you can expect to feel is that the truck will respond basically as if it had a bit larger engine, is perhaps the best way to describe it. Because the Superchip works all the time, and not just at WOT (wide-open throttle), most people see fuel mileage gains as well as improved driveability.
For most normally-aspirated engines (meaning not supercharged or turbocharged), the Superchip delivers a 10%-12% increase in peak horsepower.
There are also a couple other things you might want to look at doing, depending on just what kind of performance you want from your truck.
In general, the 3 best areas to modify, in terms of horsepower gained for each dollar spent, are: 1.) Superchip - 28 hp. 2.) Intake - using the Airaid kit that you can get here at the F150online store at a great price, this is worth a good 12 hp on the 5.4. 3.) The exhaust-use a good cat-back system, such as the Jardine or the Gibson, and the power gains vary from 10 to as much as 17 hp for the Jardine cat-back.
The sum total of doing these 3 mods is about a 50 hp gain, a little more in the 5.4's perhaps, for a total cost of just a bit over $700. Each of these mods will tend to help power *and* gas mileage, and you can do them in any order. We recommend doing one thing at a time, so you can feel what each change did for you, but you can do it all at once if you desire!
Best of luck with your truck,
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Mike Troyer
(540) 862-9515
