Chip, Computer, 351w and a ranger
I am in need of assistance from anyone with F-150 knowledge. I have a 351w from a 96 F-150. I am putting this engine into my 95 Ranger. I have the wiring harness for the engine, but I would like to know if there are any aftermarket computers. I don't really see the point of buying a stock computer, then having to buy a chip just to get rid of the governor. Face it, I'm not putting a 5.7 in a small truck just to have it shut off at 100 mph . Any assistance would be greatly appreciated. I am using a t-5 for the tranny if that helps.
HI!... Did some one mention MORE cubic inches in a RANGER? How about 408CI of small block 351-W!lol! Read lower SIG.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Hi BMRTx78,
No, there is no "aftermarket computer", you will need to use a factory computer for that 351 motor as it came in that 1996 F-150. You'll need one for a manual transmission model as well, of course. You mentioned that you have the wiring harness, you will need all the factory sensors as well, if you don't have them already with the harness.
For some of the Chevy engines there is the Accel and another aftermarket intake, that includes the intake, fuel injection, and control computer complete setup available ($1500-$2000 for openers), but there is nothing in the aftermarket for that 1996 351 motor.
Buying a factory computer and then chipping it is very cost-effective, and far cheaper than any other solution if it were available.
Sounds like a neat swap, we've seen a few V-8 conversion Rangers, usually based on the 5.0, so it's nice to see someone doing it a bit differently, with more cubic inches.
Best of luck with your project,
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
[This message has been edited by Superchips_Distributor (edited 11-21-2000).]
Mike Troyer
(540) 862-9515
Hey Neal,
I don't think I've personally known anyone with a more radical V-8 Ranger than yours Neal, and we probably won't, I'm guessing. Your Power Ranger is running the 1/4 mile in the 10's, isn't it? Put an ET in that part of your signature for us.
Mike Troyer
(540) 862-9515
Mike Troyer
(540) 862-9515
HI!... MIKE : I actually have no times on the truck yet. I pulled it off the road a few years ago to totally re-do it. The new engine has not been to the track yet. I expect it to go mid to low 10's on the motor. With the N.O.S I'm hoping for mid to high 9's for sure. It only weighs in at 2500lbs!LOL! I can't wait to get it back on the road. Then I go LIGHTNING hunting!!! LOL!
Hi Neal,
WOW!
Yeah, I'd say 900 hp on 2500 lbs. ought to do the trick to get you into the 9's, that won't be a problem if you can keep it hooked up & straight.
Mike Troyer
(540) 862-9515
WOW!
Mike Troyer
(540) 862-9515
