What Mods Best Compliment the Tuners?
Old 10-07-2004, 01:51 AM
Grunt's Avatar
Thank you so much for your responce Mike, I will Definatlly be callin you soon as im ready to start the next few mods
Thank You,
Grunt
Old 10-07-2004, 11:06 PM
rbraughn's Avatar
Mike,
I thought you posted previously that raising the 2-3 shift 2 notches to the right gave optimum results, or did I misunderstand you before?
Old 10-08-2004, 03:54 PM
Former Sponsor
Hi Colby & Grunt,
You're both very welcome, & have fun enjoying your new performance levels!
To rbraughn,
You're absolutely RIGHT with regard to the 1715 Micro Tuner, and I could have worded that a bit differently in that response - for the 1997-2003 F-150's using the 1715 Micro Tuner, we DO advise manually adjusting the 2-3 upshift point ONLY, and ONLY by taking it up precisely 2 "notches" over the default setting (the middle point on it's LCD screen - raise it 2 lines, or notches, or hash marks, whatever you want to call them, above the centerline).
As you've seen us talk about here many times before, that is a neat little driveability trick with the 1715 on the 1997-203 vehicles that allows the tranny to get back up into Overdrive quicker after it's had to downshift back down into 3rd gear like when going up a hill, etc. That is only for the 1997-2003 F-150's & Expy's using the 1715 Micro Tuners.
But in the 1714 Micro Tuners for the 2004 F-150's with the 3-valve 5.4 motor, we do NOT recommend doing that - for those, just set them at the "Superchips" setting and then leave them alone - period. That is what will deliver the best results in those vehicles. Thanks for pointing that out!
Enjoy your weekend, everyone!
Old 10-08-2004, 06:42 PM
Grunt's Avatar
Been makin a few runs were i got a 1/4 mile marked off on my road we have it marked up to a mile for settin of our work trucks... and right now im averagin 90mph whooo few more mods and ill be sweeeeeet
Old 10-08-2004, 06:51 PM
rbraughn's Avatar
Thanks for the clarification Mike, I thought maybe I made a mistake raising it on my 1715
Old 10-09-2004, 12:20 AM
Delta17's Avatar
so in this talk about the 1715 programmer, should i leave the shift pressure at the middle level, or put it 2 marks above the middle for all the shifts? I have it maxed out for all points right now...it seems a bit weird but its fun - is it gonna hurt anything in the long run, or am i loosing power because it ends up shifting harder? I will go back tomarrow and change the shift points though for the 2-3 range. Thanks for the help everybody!
Old 10-11-2004, 11:36 PM
openclasspro#11's Avatar
grunt
while this isn't a mod- this is important- for what it costs- replace fuel filter - no later than every 15 k miles- i'd say 10k- at 9000- mines was clogging- phil
Old 10-12-2004, 06:46 PM
rbraughn's Avatar
Delta17,
I think you are "flirtin with disaster" if you have all your shift pressures maxed out. I would leave everything stock except the 2-3 shift point 2 notches to the right like Mike suggests.
Experimenting with a notch here and there might not be an issue, but maxing all the pressures out sounds like a bad thing to me.
It shifts plenty hard in my 2001 Screw just with the basic settings.
Old 10-12-2004, 09:49 PM
Grunt's Avatar
Thx for the Tip OpenClassPro lol wonder were the fuel filter is on this beast
Old 10-12-2004, 11:33 PM
Delta17's Avatar
rbraughn,
I did indeed lower the shift pressures and did the two notches like mike said. I drove it for a while but then got a little bored so put it 3 above the middle setting for all points. I figure its no AS extreme, and it really dosent do much difference unless i'm heavy on the gas. But i'm sure, just to be safe, that i will put it back to the middle shift points except for the two notches because i sure dont need any problems when winter comes around in probably, and unfortantely in a couple weeks. THanks for your help and reply man!
John
Old 10-13-2004, 01:36 PM
05_Shadow's Avatar
will the underdrive pulley kit for an 03 f150 fit on on a 05 f250? it says at www.troyerperformance.com that it will fit on an 04 f150 w/the 3v engine.
Quick Reply: What Mods Best Compliment the Tuners?
