Datalogin (What exactly is needed)
starting with the xcal2 what else exactly is needed in order to datalog.
Laptop, cables, software, ect. provided I already have a laptop, about how much extra will this cost me? What would I need to purchase to do this that's not include with the xcal2? I will be ordering the xcal soon but want to see the whole picture.
A laptop and the Xcal2 will be all you need to datalog everything except the A/F ratios. It comes with the cable you need and the software is a free download from sctflash.com. For the A/F ratios you'll either need to make a trip to the dyno or get a wideband A/F ratio recorded. They will send you all the datalog documents when you order the Xcal2.
How long is the data logging process? Is it something you do in a couple passes on a dyno or is it certain amount of miles. Do you do it under normal driving conditions or is it everything from idle to WOT? Do you do the data logging with your tunes installed if so do you have to data log for each tune?
Mike posted recently that he has a way to get around the a/f ratios, and can tune from the datalogging done with the XC2 alone.
You still need a laptop.
I have the LM-1 a/f wide band logger, and I am looking for a cable to connect it to the XC2......anybody??
I am finding the whole process of getting prepared to data log a PITA, but I installed the wideband permanently and that was more work.
It should be fun, and very worthwhile when it all comes together.
Mike has always said that the late model 5.4 3V really needs to have their A/F ratios figured to ensure you are not running a dangerous lean condition and get the full use out of your tune but I got a hint in his "we are off to SEMA" post that there might be a way around it.
https://www.f150online.com/forums/sh...d.php?t=216325
Where did you get the LM-1 from? In the LM-1 RPM kit you should get everything you need to record the A/Fs and RPMs.
It will require at least 5 pulls on a dyno to get the info they need.
You datalog no load in neutral as well as at WOT.
You datalog with each different tune so they can see what's happening with every tune.
HTH
The real problem here is explaning to my wife why I need to take our $40,000 family truck to the dyno! Or spend another $400 ontop of the $500 (for the programer) she dident want me spending in the first place. Anyone else have this problem???????
http://www.sctflash.com/forum/showthread.php?t=1751
