AF1 missing parts upon arrival
This is SO disappointing. I had to wait for the AF1 due to backorder. Then when it finally gets here, all I can do is LOOK at it!
Has anyone else had parts missing for the AF1?
I guess it's supposed to have two breather hoses that aren't in there.
Having to stare at it is going to be worse than waiting for it to get here.
Sorry guys, just had to vent. I guess I'll go back out and put my tools away.
My kit was missing the 1/8 seal that goes in the round cutout of the heatshield. I called them and they sent me one, no problem.
Other than instructions that aren't really complete (why isn't the support bracket bolt stackup better explained?), everything went smoothly with my kit and installation.
Call Everett at AF1 and explain your problem. He'll take care of you.
BTW, I received and installed mine this past January.
Originally Posted by gonecampin
It's a 5.4
The instructions don't say anything about the 5.4 NOT having them. The parts list says they shouls be there, and the coupling has a spot for both of them to connect. It sure seems like they should be there.
mind is a 2005 5.4 one tube on one side (Factory breather tube) mass air on the other side..... look close at my pic, you can see the tube.... unless they have changed something....
Hi Gonecampin,
Sorry to hear you had a problem!
If that kit was ordered from us, all you need to do is call us & we get that kind of thing taken care of right away - if you ordered it elsewhere, then you'll need to deal with your vendor, or you can call AF1 directly.
We are their oldest & largest distributor, and did the R&D on some of their kits, so we have a very close relationship with them. Those kits are in heavy demand, so they did get a bit behind on them - we order them by the hundreds, but even we sometimes run out!
And yes, there is a difference between the 1997-2003 5'4 2V kit and the 2004 & up 5.4 3V kits.
Good luck with this, and if it came from us, please do give us a call if you have any problems, OK?
Originally Posted by F150Truck'in
yes this is a all F150 forum, but the thread you are posting in is a 2004-2006 F150, sometimes we get confused trying to help people posting older F150 in here....but I understand posting in here, there's no 1998-2003 F150 thread..
I know know why, that would be a question to ask Steve (webmaster)
anyway, don't get me wrong, just understand when you get misleading info...
