First Impressions with Troyer Tune
Got my tunes emailed to me today right before work and installed the 87 MAX tune. Troyer sent me the 87MAX, 91MAX and 91TOW. Too bad for me that I filled up with Chevron 87 right before going home and seeing the email.
Right off I noticed the truck shifted a lot firmer, accelerated quicker, and seemed to idle better. I also noticed that I had some detonation right off the line as I accelerated. Sounded like a diesel kinda “snorting” and then a little more pinging as it accelerated up through the rpm's at half throttle-full throttle.
I called Troyer and the person I spoke to suggested backing off the timing 2 degrees throughout the RPM’s and see how that works. He also said I should try a different type of fuel to see if that helps. Once I get through this tank of gas I will fill up on 93 octane and do a datalog. Hopefully they can tune that out.
So far so good, except for the detonation, which I think they can tune out, I am impressed with the tune!
Dave
Dave
Originally Posted by Deeve
Hmm, I checked all the paperwork I have and did not see a suggested fuel list. Do you have a copy of it that you could email me? I have the datalogging instructions, installing the tunes instructions and the worksheets.
Dave
Dave
Fuel Quality, Fuel Economy, Etc.
should be there......
The Chevron isn't.
Up here (I'm not far from Portland) I've tried all the premium fuels, and have the best overall response with the Chevron though. Shell seems to give me a little better mileage, not by much, but the Chevron just seems allot better performance and smoothness. Seems weird. I get about 14 around town driving and 18 highway with the chevron. Very hilly driving around here.
Jon
Jon
I believe it has a lot to do with the area you are located and the ownership of the gas station too. I put Shell in my car last week and it was knocking & pinging. Then on the way to work this morning I put Wal-mart gas in there and it was back running like a top. Makes me wonder what gas I need to put in my truck.
This is very simple - any fuel that causes your truck to detonate with our tuning is an *extremely* poor fuel - and this is precisely why why we provide such highly detailed info on fuel quality in our documentation that gets sent to everyone who orders our custom tuning.
One brand name might work fine in one area, but be *terrible* 20 miles away, or at another station right across the street - and Chevron our in the northwest is a very suspect fuel, we have a LOT of complaints with that fuel in that area, which is a shame, as it used to be one of our preferred fuels a few years ago.
Now it is not possible that a fuel that gives you a lower MPG also gives you better performance if the octane is actually the same in both fuels - that can't happen. The MPG and the performance come from the same thing - the energy content - assuming that the actual octane is in fact identical, of course. Just some food for thought - you might be seeing some undocumented variance in octane.
Nobody should have to remove timing from any of our tunes - that happens *only* when *extremely* poor fuel is being used - and is cured by simply using a better quality fuel. This is important to remember, and once again, is one of many reasons why we provide all the info we do about fuel quality in our docs.
I hope that helps, & good luck!
Thanks Mike, after reading about the fuel in the docs (once I found where I unzipped the files to) it looks like I will be finding a 76 gas station to use or Texaco. I really like the way the truck pulls with just the 87MAX! Totally different truck that feels like it has the power to match the sound of the Magnaflow! I imagine it will get better with better fuel too.
Thanks!
Dave
Thanks!
Dave
