just got the edge evo
After much searching and weight out the various info on the tuners avaliable for my truck I made a choice. I went with the edge evo and think I made a good choice. So far all I have run is level two and happy with the results. I also like the gauges the edge has to monitor various aspecs of the truck. I think for an everyday driver with limited mods this tuner will cover what I need. However not being able to try out the xcal2 I can not make any comments on that unit. If however I wanted to truely dial in my truck and have alot more mods I think the TP custom tune is the best choice. Plus I always see Troy on these pages helping out.
Any way when I try out level 3 I will get back too ya.
1-As long as I have high octane I can run at 3 all the time?
2-What is the I in IMPG? I know dumb question, but oh well
3-The A in AMPG is "actual miles per gallon"?
4-Is there a "break in" time, I mean does the truck have to get used to the new settings and will run cleaner/better?
5-Velcro placement, where is the best?
6-What is the 3M strip for?
7-How many licks does it take to get to the center of a tootsie pop?
Sorry if some of these are just plain goofy questions, I am very new to this....Thx
Originally Posted by jager
Congrats, I just got mine yesterday and installed it before the UPS truck was off the block! so far happy with the results, I have mine set at 3 since I took out a 2nd mortgage and filled the tank with 93...OUCH!!!Couple of questions:
I= instant mpg
a= average
I sure there is somee amout of time for the pcm to learn the new progam
5 & 6 I can't answer because I'm not going to use the pod. going to make something custom.
7. don't lick just chew it. my son don't know he never made it there.
I think you can run on level 2 with the higher octane. level says 87 octane or better.
I= instant mpg
a= average
I= instant mpg
a= average
1. Yes
2. Instantaneous/Instant
3. A = Average
4. I never really noticed a difference, but some people have. The answer is "Probably"--try a search for threads on "adaptive strategy"
5. The velcro works best at the ends of the pod (where the pod actually lays flat against the dash).
6. The 3M tape is used in lieu of the velcro if you want to permanently mount your pod. Not recommended unless you never plan to remove the pod from your dash.
7. a-One, a-two, a-three... three.
Guest
Posts: n/a
I like it alot............
I have been playing with changing the splash screen. I found a pic of a girl sitting on the ford logo. And got it to fit on the screen. I'm on the look out for more pics. If anyone wants the ones I come up with just let me know and I will send it to you.
As for adaptive strategy, yes, it really exists. I thought this was a bnch of bs, like audiophiles talking about cable "break in periods" until I saw it in action. I was very pleased with the Edge when I got it. I have had it for 5 weeks now and it is even better. Not that it means anything but when I got it I wasn't able to chirp the tires, now I can lay 15 feet of rubber on the pavement and have to pay attention when launching.
Also, regarding the higher octane, yes, if you are running the higher octane gas you can run any of the programs, and as is states in the manual, you can advance timing by 1 for every 2 octane points.
Originally Posted by yamaha619
What is involved when installing one of these? On my Cummins I had to actually drill for the sensor probes of the transmission, boast, EGT, etc... Do the Fords already have all these sensors in place? Is it just a simple plug into a port and it starts working?
For the gas engines, they plug into the ODBII port and get the readings from the PCM. Great product from what have seen.
And I own an XCal II
Email is vince12_200mph@yahoo.com
Thanks.
